Resources
Back Issues
Physicists Study Colliding Atoms With a Laser Tracker
Quality Documentation Automates Aerospace Company
Leica's LTD500
Hundreds of physicists from around the world come to Brookhaven National Laboratory to study what the universe might have looked like in the first few moments after its creation. The laboratory in Long Island, New York, is a world-class scientific research facility that began operation of its Relativistic Heavy Ion Collider in 2000, following 10 years of development and construction. RHIC drives two intersecting beams of gold ions head-on in a subatomic collision that forms heat and new particles. What physicists learn from these collisions may help them understand more about why the physical world works the way it does, from the smallest subatomic particles to the largest stars.
Using Leica's LTD500 laser tracker system to ensure accurate alignment of the beams to within 0.050 mm (50 µm), Brookhaven physicists are able to align the intersecting beams of gold ions to ensure head-on collisions. The 3-D measurement system is a robotic laser interferometer incorporated into Leica's Axyz software, used for large-scale metrology. The interferometer is the standard calibration instrument for distance measurement, measuring distance by counting wavelengths of light in a differential scheme. The LTD emits a laser beam, and a reflector located on the object returns the beam along a parallel path back into the sensor head. The returned signal is used to calculate the distance to the reflector. The tracker head continuously traces the movement of a prism and reports coordinates.
RHIC, the world's newest and biggest particle accelerator for nuclear physics, comprises several accelerators working together to produce collisions of heavy ions--atoms which have their outer layer of electrons removed. The RHIC collides two beams of gold ions as they travel in opposing orbits at 99.95-percent the speed of light. At such a speed, the gold ions appear to flatten and then collide. The collision is transformed into intense heat and new particles.
Physicists sift through these particles' energy and type for information to help them understand more about the physical world. The RHIC produces collisions that occur thousands of times per second. Each one acts as a microscopic pressure cooker, producing temperatures nearly 40,000 times that of the sun.
Leica incorporated the laser tracker and the multihead theodolite modules into the Axyz system to database the results of the 3-D points generated in space. The system is capable of taking 1,000 measurements per second and has an overall accuracy of 0.001 in.
Physicists work in 3-D when surveying these experiments to examine the layout of magnets and detectors, which is structured and formal. The nature of object location can take place in presurvey mode, in which an object's internal mechanical or magnetic features are measured and related to external fiducials for layout, or in post-survey mode, in which an object is located after the beam operation.
The successful implementation of the Leica LTD500 allows Brookhaven physicists to bring the RHIC up to full collision energy of 100 billion electron volts (GeV) per nucleon. Until then, the RHIC was colliding ions at a maximum energy of 65 GeV. With these higher temperatures, the chances are increased of colliding particles reaching "boiling point," the temperature at which quarks and gluons can escape from inside protons and neutrons. This added energy produces more than 100 times the data than did collisions during the first year of the RHIC's operation.
Leica's LTD500
Benefits:
  • Internal automatic function control
  • 3-D determination
  • High-precision angular encoders for a diameter of 70 m
  • Measuring rate of up to 1,000 points per second
www.leica-geosystems.com
