Using MIL-STD-105 As a Process Control Procedure
In the politically correct world of PPM defective, MIL-STD-105 is a misunderstood and misapplied specification
Anthony Chirico
Mon, 10/08/2018 - 12:02
  • Add new comment
All articles in this series
The Paradox of Acceptance Sampling
Applying the Procedures of MIL-STD-105 to Imaginary Limits
In my previous article, I discussed the merits and cautions of the “acceptance number” equal zero (c=0) sampling plans contained within AS9138. A simple formula was provided to determine appropriate sample size, and it was illustrated that twice the inspection does not provide twice the consumer protection. Although there is an undeniable emotional appeal to implement sampling procedures that have an acceptance number of zero, readers must not jump to the conclusion that c=0 sampling procedures provide better consumer protection at the designed lot tolerance percent defective (LTPD) point.
In this article the merits and limitations of MIL-STD-105 will be illustrated, and its link to process control will be demonstrated. Before discussing the technical merits of MIL-STD-105, its impressive evolution deserves some recognition.
Submitted by S. Piazza (not verified) on Mon, 10/08/2018 - 11:14
Using MIL-STD-105 As A Process Control Procedure
Surprised a guy from RIT didn't work-in Dr. Schilling's name as a huge contributor to Acceptance Sampling techniques.
1 + 14 =
