Lean Nesting
An important element frequently ignored
Thomas R. Cutler
Tue, 08/26/2008 - 22:00
  • Add new comment
One of the most demanding problems lean manufacturing faces in discrete manufacturing is control of first operations, where raw material may be cut into multiple parts. First operations such as laser or CNC Punch Press processes dictate what parts are available to subsequent operations, thereby controlling much of the downstream process flow.
Building an optimal nest of parts is a complex problem. Nesting isn’t axiomatic. The ability to read an active-order file for the current demand of parts, extract the appropriate ready-to-nest parts, drawing upon parameters established to create the optimal nesting pattern, is far from axiomatic. A host of factors must be considered, from material efficiency, part priorities (today’s orders, hot parts, filler parts), setup costs, order completion, labor, and machine throughput to name a few.
Submitted by jdanielgs on Fri, 09/12/2008 - 23:36
Use of words
A very good article, Thomas. But please, don´t write "most optimal", since it has not sense. There exists only one "optimal", not a better one or a worst one.
Daniel
Servicios de Optimización y Estadística, S. C.
3 + 15 =
