Avoiding Common CAPA Pitfalls
Strategize for an effective regulatory framework worldwide
Edna Falkenberg
Thu, 09/18/2014 - 14:29
  • Add new comment
The regulatory landscape continues to change. One of the quality system approaches defined by regulators and the industry for mitigating risk is corrective and preventive action, better known as CAPA. Companies are often challenged by the CAPA process, which is one of the most important and essential elements of a quality management system within the regulated medical device industry. A CAPA program, effectively implemented and integrated, can affect all areas of an organization, including production and process control, design, purchasing, and more. An inadequate execution of a CAPA strategy continues to be one of the most common nonconformities cited during audits and inspections within highly regulated environments.
To develop an effective and robust CAPA system and management process, it is important to oversee compliance and analyze relevant metrics and measurements. An understanding of the regulatory requirements of certain countries, depending on the nature of your organization and supply chain, is also critical. All of this must be integrated into the system.
Submitted by Dave Gentile on Thu, 09/18/2014 - 14:13
Question
Edna, I've been unable to get your contact info via Google or TUV without going through a paywall. It appears that you are a CB Auditor. If so, how do you justify presenting a CAPA webinar, which can be construed as Consulting?
The points you make in this article are very good ones, but I'm opposed to the concept of CAPA - they should not be conflated. Preventive Action is about Prediction and Planning. Corrective Action happens when Preventive Action is not done well.
15 + 0 =
