The Neglected Half of Lean Thinking
Think people assets, not people waste
Robert A. Brown
Tue, 03/26/2013 - 09:43
  • Add new comment
Chances are you are not fully satisfied with the results of your lean initiatives. It’s also likely that lean thinking is not used to improve your employees’ skills in working together. That’s because you are using only half, probably less, of the power of lean thinking.
In 2001, Toyota declared that its success rested on two pillars: continuous improvement and respect for people. However, people in association with waste have been essentially ignored.
It’s easy to observe an assembly worker’s operational processes. What about someone daydreaming during a meeting? Is daydreaming in a meeting a waste to eliminate?
Nonproduction activities use a different kind of lean component. One objective of production is to pass a defect-free output to the next process in the value stream. What is a defect-free output for knowledge work and interacting with other people? That output is not so clear.
Submitted by umberto mario tunesi on Tue, 04/02/2013 - 01:53
Managers from Hell?
Or managers TO hell? Dante Alighieri in his Divine Comedy lists quite a number of VIP's who deserve Hell. No portion of lean thinking will ever cure the business maladies, until managers will think in terms of money profit, only.
6 + 1 =
