Four Types of Asset Maintenance Strategies
Each has its own set of key performance indicators
Photo by ThisisEngineering on Unsplash
James Chan
Wed, 10/09/2024 - 12:02
  • Add new comment
Asset maintenance isn’t just about fixing things when they break. It’s a complex mix of strategies, both proactive and reactive. Finding the most cost-effective blend makes all the difference in the success of your maintenance program and your business as a whole.
Whether your team is scrambling to put out fires or using cutting-edge predictive tools, the type of maintenance program you use dramatically affects downtime, costs, and the lifetime of your equipment. Managers and technicians alike should be well versed in the different types of asset maintenance to ensure they’re fully prepared to keep machinery humming.
Submitted by qbcert on Thu, 10/10/2024 - 05:31
The Importance of Tailored Asset Maintenance Strategies and ISO
This is an excellent breakdown of asset maintenance strategies! I appreciate the clear distinction between reactive, preventive, and predictive maintenance approaches. Each strategy has its place depending on the asset's criticality, and the article does a great job explaining when and how to apply each. The emphasis on data-driven decisions in predictive maintenance is especially relevant in today’s tech-driven environment. It’s clear that a well-balanced, flexible maintenance program can significantly reduce downtime and optimize costs. For those looking to align their maintenance strategies with ISO 9001 standards, ensuring operational efficiency and continuous improvement is essential. I also agree that ongoing training and the use of tools like CMMS are critical for successful implementation. Great read!
1 + 17 =
