Wouldn’t You Want to Know?
It’s not the tool but how you use it
Dan Nelson
Mon, 12/16/2013 - 12:30
  • Add new comment
Nobody likes to be told they’re doing something wrong. But if you were doing something wrong due to a misunderstanding, and it was actually hindering your operations while adding unnecessary cost, wouldn’t you want to know?
For example, let’s assume that you are using a tool consistently with accepted practice. Yet this tool produces poor results for you and others you know who use it. Even after years of trying, you don’t seem to succeed. The tool causes more trouble than it’s worth.
It would seem natural to reject the tool, right? But let’s assume that rejecting the tool is not an option, for whatever reason. So you must continue to use this tool although it doesn’t work and you don’t like it.
Now, if in reality the problem was that you were using the tool improperly this whole time, actually contrary to the manufacturer’s instructions, would you be interested in knowing that? Or, since you must still use this tool, would you rather continue misusing it, thereby continuing to add confusion and unnecessary cost to your operations?
Of course you would want to know, right?
Submitted by Dan Nelson on Wed, 03/05/2014 - 08:56
Error
An error appears in this article. Deming is not mentioned by name in ISO 9001, contrary to what is stated. PDCA is explicitly mentioned in ISO 9001. Sorry about that.
Submitted by Quality Digest on Wed, 03/05/2014 - 09:12
In reply to Error by Dan Nelson
Fixed error
Thanks for catching that Dan. We should have caught the error as well. We have removed that bit.
5 + 15 =
