If It Ain’t Broke…
Problems with narrowly defined projects
Mon, 01/30/2012 - 11:17
  • Add new comment
The objective of all improvement projects should be to improve the effectiveness, or the efficiency, of the core processes. Everything else should be secondary to this objective. If you improve the efficiency of a support process, or even a portion of the core process, but at the same time lower the overall efficiency of the core process, what have you gained?
Submitted by vunderbolt on Thu, 02/02/2012 - 17:41
Did you manage to convince the Company?
Dear Donald, Your article again highlighted the obvious (in hindsight). I thought of a story my father always told: There was a man that believed that he was a grain of corn, which is staple food for chickens. As such he was dead scared of any chickens. He went for some psychological treatment and eventually the psychologist convinced him that he is not a grain of corn and does not need to be scared of chickens. As a final test they asked him to go into a room where they placed some chickens. He scarcely went into the room when he came back sweating and really scared. He looked at the Psychologist and said: "I know I am not a grain of corn, but do the chickens know it?" Do you find that you can convince Companies of the problem with measuring in silos? Kind Regards Francois
Submitted by Donald J. Wheeler on Fri, 02/03/2012 - 06:31
In reply to Did you manage to convince the Company? by vunderbolt
Reply to Francois Vunderbolt
When a company is a learning organization, which is data driven, then I do have some success at getting them away from looking at each department separately. At other times, you are correct in assuming that they keep doing the same things they have always done, and getting the same results they have always gotten, while they keep hoping for different results.
4 + 14 =
