Resources
Back Issues
by Bertrand Gili
Take the manufacturer’s logo and some sheet metal off of a coordinate measuring machine, and what you have is a steel frame, a granite table, bearings, motors, scales and a controller. Whether six months new or 15 years old, they all look about the same. Furthermore, they all can last a long time. So how do you know when it’s time to replace or upgrade your existing CMM? What should you consider when faced with this decision?
One of the most important considerations will be the software. It affects almost every facet of your CMM operation: keeping or replacing the existing controller, maintaining compatibility with existing software and parts programs, ensuring offline programming capabilities, and integrating data from other shop-floor CMMs or outsourced inspection services.
Machine accuracy
Very often, a CMM--even an old one--will continue to provide years of use with only a software or software/controller change. The basic machine, however, must still be capable of performing to specifications. If a CMM has been maintained and calibrated annually, its repeatability and positional tolerances are still highly accurate. A common way to verify this is by confirming volumetric accuracy using one of the quality standards in place (e.g., ISO 10360-2 or ASME B89.4.1). If the results show that the CMM is out of specification, several remedies are available:
Fine-tune or mechanically adjust the CMM for linearity and squareness. Replace or remanufacture bearings and bearing surface areas, if necessary.
Add a volumetric compensation file, also referred to as an error map. Most CMMs have proprietary error-mapping software that compensates for volumetric defects created when the machines start to wear.
Outsource to companies that provide complete controller retrofits or simple software upgrades, including calibration and error-mapping services. These companies can replace motors, cabling, scales, bearings and other components.
However, depending on the CMM’s style and size, this might prove too costly.
The controller
If the CMM hardware demonstrates acceptable volumetric accuracy, you must turn your attention to the controller and the inspection software that runs it. This is where you’ll find the most significant difference between older CMMs and new ones. Consider what you saw when you last attended a vendor’s CMM demonstration: the machine, of course, but mostly a computer screen.
Controllers have become smaller and more reliable. Today’s controllers can be 60 percent smaller than those designed just 10 years ago. Much of the wiring and boards have been reduced and replaced with common and readily available components. Many new controllers are modular and easy to upgrade to support scanning and laser technology.
Several universal controllers on the market are designed to fit any type and brand of machine. Metrologic Group, for example, designs DCC controllers and counting boards with versatility and adaptability in mind. These controllers can connect to any CMM using most existing electronics and wiring. Renishaw has also released its own universal controller, opening the market to universal retrofits.
One consideration when keeping older controllers is cost and availability of replacement parts. Consider where the CMM lies in your company’s critical manufacturing path. Some replacement parts can be expensive and require lengthy lead times for delivery. New controllers come with warranties, and replacement parts are usually readily available. Should the CMM break down, consider the cost of holding up the manufacturing process, sometimes for weeks, while replacement parts are procured.
That said, retrofitting CMMs by replacing the OEM controller is a concern for most customers, either because of the cost or rework time caused by unreliable and unskilled companies in this sector. An alternative to retrofitting is simply to upgrade the CMM software with an independent software solution that will connect directly to existing CMM hardware. This alternative keeps the CMM hardware intact and also offers many of the advantages of a new CMM, including new software and error map capabilities, at a fraction of the cost. It also enables you to run legacy software because no hardware modifications are required. However, you must ensure that any new controller software is compatible with your existing controller.
Inspection software
The most significant advancement in CMM functionality has been made to the inspection software. During the last 15 years, online inspection software has evolved from a primitive, text-based programming machine language--limited to driving a CMM to specific locations and collecting results from data points within an X, Y and Z coordinate system--to Windows-based, icon-driven programming fully capable of simulating work cells, reverse engineering, graphical reporting and data analysis. Other major advancements include the ability to program directly from 3-D computer-aided design data, scanning support and laser technology.
In today’s manufacturing environment, the trend is to have 3-D CAD data at the heart of every manufacturing process. CAD systems enable designers to model tooling, fixtures, parts and finished assemblies with complete dimensional specifications in a digital environment. Designers can validate all aspects of the design even before the first parts are made.
Of course, the most accurate results can only be achieved by comparing actual parts to the theoretically perfect CAD model. This is accomplished by using CMM software that can create programming code simply by selecting surfaces and features directly from the CAD model. This code can drive the CMM and probe or scan selected surfaces. The resultant data represent the deviation between the actual part and the theoretically perfect nominal of the CAD model. These results can be formatted and output in a variety of graphical report formats, including HTML. They’re much easier to interpret and enable engineers to see the deviations in the part by means of color maps and vector graphs.
The variety of CMM software available includes online control and offline programming software that can be used to write CMM programs utilizing fully dimensional CAD models. This ability to program existing CMMs using a Windows-based graphical user interface has not only decreased the time it takes to write the programs but also increased the accuracy of the results and cut down on the time needed to analyze the data. Writing programs using a CAD model has enabled third-party software companies to develop offline programming software that’s independent of the CMM and can run either on the CMM’s computer or a stand-alone PC. This allows users to write programs offline instead of disrupting the CMM’s scheduled workflow.
Some offline programming software, such as Silma’s CimStation Inspection, enables the programmer to create complete virtual work cells that include the CMM, probing system, rotary tables, probe changers and CAD models. During simulation, the software can detect collisions and either automatically edit the path to clear them or alert the programmer that a collision would occur if the program were run on a real CMM.
Many CMMs are utilized less than 50 percent of the time to actually check parts. The rest of the time is spent writing and editing programs and setting up the part. By contrast, offline programming can be written as soon as the CAD model is available, which enables the programmer to design the program much earlier in the production timeline.
In Silma’s software, programs are written in native DMIS, fully simulated, tested and generally written in much less time. They are then ready to be run in their native format or posted in many proprietary OEM formats without the need to program in these languages or write several programs for each target machine.
Software standards
Many different CMM hardware manufacturers compete in the manufacturing industry. To give themselves an edge, each has developed its own proprietary online control software to drive its particular CMM.
Some CMM manufacturers, lacking the software development resources to keep up with the industry’s ever-changing needs, have looked to third-party software providers to design the inspection software. This has created a problem not only for large corporations with multiple brands of CMMs, each with its own unique programming language, but also for companies that deal with suppliers or customers that use different CMMs. The programs are often incompatible and must be rewritten; it’s not surprising, therefore, that the results tend to vary. The added expense for rewriting programs and reanalyzing results has been estimated to run in the billions of dollars industrywide.
These issues have prompted an initiative for standardization, driven primarily by the automotive industry. The goal of CMM standardization is to allow users to write programs in one common control language, both online and offline, supported by one common graphical user interface that can drive any brand of CMM.
CMM components, such as the probing mechanisms and controllers, should be interchangeable. Ideally, users should be able to choose system components based on their companies’ particular needs, and all these components should be easily plugged together and communicate properly. Thus, CMM hardware could be evaluated based on the work envelope, speed and accuracy. The probing system and controller could be evaluated based on its ability to access necessary features and support touch probes as well as scanning or laser technology. Finally, the inspection software could be evaluated based on its functionality, ease-of-use and ability to accurately gather the required data for analysis.
These issues have spurred several trends in the industry that will affect how well a software package will meet your existing and future needs:
Standard programming language (DMIS). The Dimensional Measuring Interface Standard was developed by the Consortium for Advanced Manufacturing. DMIS is a neutral programming language that’s widely accepted in the industry and approved by the American National Standards Institute. Most CMM manufacturers are standardizing to the DMIS programming language by using either a DMIS engine or converter. The amount of DMIS that is supported varies by CMM manufacturer. Typically, if the software has a DMIS engine instead of a DMIS converter or translator, it more closely adheres to the DMIS standard and allows users to open, modify and save part programs without any import/export losses in conversions.
Universal controller protocol (I++ DME). Whereas DMIS provides a universal language at the application level, I++ DME provides a universal language to communicate with the controller. Without this, third-party software must be able to communicate with scores of different controllers in the field. Although there’s some concern that I++ DME won’t be supported by OEMs because keeping a proprietary language gives them a competitive edge, industry pressure could force them to support it. For that reason, selecting software that supports I++ DME should be one of your considerations.
Universal controllers. Addressing the proprietary controller language mentioned earlier, Renishaw, which has been providing its touch-trigger probes to most CMM manufacturers, has developed the UCC1 universal controller. Unlike the OEMs, Renishaw makes its controller language available to third-party software producers such as Metrologic.
Purchasing for the future
Reliability, flexibility, speed and accuracy are what today’s CMM buyers seek. They’re looking for an easy and powerful front-end, and software is what ultimately pushes them into purchasing. The CMM industry is drastically changing, focusing on software performance. OEM software might soon make way for independent software companies dedicated to developing the best possible application for online and offline programming, irrespective of the types and brands of measuring equipment.
To choose the most appropriate software for your company, keep in mind that the program must not only meet your current needs but also anticipate those to come. It was only a few years ago that a well-known and independent company first offered a universal operating system software for personal computers, leading PC manufacturers to focus on developing hardware only. CMMs face a similar change, and smart customers will purchase with this future in mind.
Bertrand Gili is president and CEO for the North American operations of Metrologic Group and Silma. Metrologic specializes in the design and manufacture of 3-D control software and electronics. Metrologic has developed more than 45 direct machine interfaces to connect its software to any controller, including those from Brown & Sharpe, Leica, Zeiss, LK, Faro and more. The company also offers CMM retrofits, calibration, on-site support, training and maintenance services.
More information is available by visiting www.metrologicgroup.com or www.silma.com.
