Seven Steps to Management Systems Certification
From commitment to follow-up
Daniel Desilets
Wed, 09/14/2016 - 15:31
Sponsored content
Y our product or service is only as good as the management system that supports it. Certification by an independent third-party certification body, such as Intertek, confirms that your management system complies with the respective international standards for quality, sustainability, work health and safety, or risk management. Management systems certification assures you and your customers that your business process is designed for continual improvement to meet requirements and regulations, and to understand and mitigate any potential risks.
The path to certification consists of seven steps—and Intertek’s professionals will be there to guide you throughout the entire process.
Seven steps to certification
1. Commitment. Once you’ve selected Intertek as your certification body and your audit date is set, you’ll be assigned a lead auditor to guide you through the entire process. Intertek has a network of professionals who will help you receive the personal and insightful service you deserve.
12 + 7 =
