ON-Delay Industrial Interval Timer
Instantaneous relay and 12 timing ranges in a single unit
Marsh Bellofram
Wed, 12/07/2011 - 13:08
(Marsh Bellofram: Newell, WV) -- Marsh Bellofram Corp., an AS9100:B- and ISO 9001-certified global manufacturer of high-performance OEM, industrial, and process control instrumentation, has introduced the 405AR series, an economical industrial timer family with ON-delay instantaneous relay functionality, designed for a variety of daily-use OEM and control package timing applications.
The Marsh Bellofram 405AR series features 12 individual timing ranges within a single unit, packaged within a highly compact eight-pin 48 mm-squared DIN-Size housing. The housing is watertight when panel mounted with an eight-pin round (octal) socket. The timer operates from an industry standard 24–240 VAC or 24 VDC power supply, and features a large and easy-to-read display dial with decimal points and 10A DPDT output contacts. Mode and range select switches are located on the side of the unit, so that when panel mounted, they are not operator accessible, a tamper-proof feature that prevents unauthorized or hazardous changes to the timing mode and range. A special LED indicator provides a unique and effective flashing method of cycle progress indication.
2 + 1 =
