Eight Problem Solving Traps
Understand that effective problem solving often consumes more time
Timothy F. Bednarz
Thu, 03/15/2012 - 12:01
The process of problem solving can at first blush appear relatively simple: The difficulty is defined, facts and evidence are collected and analyzed, and a solution agreed upon. However, because imperfect people make decisions, the entire process is fraught with traps that can lead to serious errors in judgment.
Problem solving should not be taken lightly: It is a step-by-step process that when properly sequenced and followed should produce solid results. Unskilled problem solvers will often misinterpret the issues, attempting to solve symptoms rather than root causes, and make the situation more confusing than it has to be.
It’s important for individuals to understand that effective problem solving often consumes more time than most people are willing to invest. Rather than go about it properly, many just want to react and deal with the problem quickly. However, the time invested to thoroughly investigate and solve a problem more often than not produces a more successful solution—and happier employees and customers.
6 + 2 =
