Two Maps, One Value
The value-stream map has been around longer than you think
Eston Martz
Mon, 12/02/2013 - 11:42
In looking for the answer to an unrelated quality improvement question the other day, I ran across a blog post that answers a question I’ve had for a while: What’s the origin of the value-stream map?
A value-stream map is a key tool in many quality improvement projects, especially those using lean techniques. The value stream is the collection of all of the activities, both value-added and nonvalue-added, which generates a product or service that meets customer needs. The value-stream map shows how both materials and information flow as a product or service moves through the process value stream, helping teams visualize where improvements might be made in both flows.
In his post, Michel Baudin traces the history of a process map that accounts for both materials and information back to a text published in 1918, and provides examples and documentation of how this idea has been applied, transformed, and popularized since then.
6 + 0 =
