Six Packaging Quality Control Checks
Steps companies can’t afford to skip
Chicken packing line from Flickr
Emily Newton
Mon, 07/25/2022 - 12:02
Staying on top of packing quality-control measures can have positive ramifications for companies. For starters, products are more likely to arrive undamaged if they're in appropriately robust boxes. There’s also a safety element involved. Suppose a fragile item shatters in transit due to improper packaging. If the broken item has sharp edges, a person could be cut while trying to open the product. They might not even realize anything’s wrong until they reach inside and get hurt.
Fortunately, following an established set of checks can prevent such issues. Here are some steps not to overlook.
1. Test the package’s strength
It’s essential to see how a package will hold up when subjected to the many stresses it may undergo from the time it leaves its original location to when it reaches a final destination. The edge crush test is one of the best-known ways to check resilience. It’s a compression-based method to see how well a box retains its shape when placed in a stacked orientation. The most accurate way to perform it is to put the package between two metal plates and program a machine to exert a particular amount of force.
11 + 0 =
