Rapid-Loc Pneumatic Vise for CMM Inspection
Phillips Precision’s latest features regulated air pressure and holds up to 150 lbs
Phillips Precision Inc.
Tue, 03/24/2015 - 12:29
(Phillips Precision: Boylston, MA) -- Phillips Precision’s products division has introduced the Rapid-Loc pneumatic vise for CMM inspection. Designed to take advantage of the air at your CMM, the soft jaws of the Rapid-Loc vise can be customized to hold most parts. Regulated air pressure can produce just enough clamping force to hold delicate parts or as much as 150 lbs if needed. Mount Rapid-Loc vises on Inspection Arsenal Loc-N-Load quick-swap fixture plates for fast, accurate, and highly repeatable setups that help break inspection bottlenecks. Rapid-Loc can also be mounted on existing CMM breadboards.
The black anodized, aluminum Rapid-Loc pneumatic vise is currently available with a 2.5 in x 3.5 in. footprint, .06 in. travel, 150-lbs of force, and comes with a set of machinable aluminum soft jaws. Secure Rapid-Loc with standard or metric thread screws.
A smaller vise is under development and will be released for production later this spring.
3 + 7 =
