Morehouse Instrument Offers New Digital Force Gauges
Retrofit options also available for analog-type gauges
Morehouse Instrument Co.
Wed, 07/26/2017 - 12:00
(Morehouse: York, PA) -- Morehouse Instrument Co. has introduced new types of digital force gauges. These digital gauges offer improved performance and accuracy specifications. Compared to a typical analog ring force gauge with 0.5 percent of full-scale accuracy, these new gauges are two times more accurate at 0.25 percent.
Repeatability, resolution, and reproducibility are also significantly improved. The new Morehouse digital force gauge displays direct-force values and does not need an interpolation table. It offers several features, including a max-hold button. It records peak and valley forces, and is programmed using 11–12 data points taken from Morehouse-accredited deadweight calibrations accurate to 0.002 percent of applied force.
Additionally, the gauge features the new TIR function when the gauge displays the difference between maximum and minimum forces, while recording the maximum and minimum values in memory. This function can be of major assistance in varying force applications.
1 + 0 =
