Mahr Introduces the Precimar SM 60 Length Measurement System
Provides fast and precise external measurements on manufactured parts
Mahr Inc.
Tue, 09/10/2019 - 12:00
(Mahr Inc.: Providence, RI) -- Mahr Inc., a leading provider of dimensional metrology solutions, has introduced the Precimar SM 60, an easy-to-use length measurement instrument for fast and precise external measurements on shop floor parts, with a measuring range of 60 mm.
The SM 60 is configurable with Mahr readouts, such as digital indicators or linear variable differential transformer (LVDT) probes, to provide a system tailored to the performance level required for the measurement application. The SM 60 incorporates a 25 mm sensitive contact and a fixed reference jaw with a 35 mm adjustment to obtain the full 60 mm measurement capacity.
The robust construction of the SM 60 demonstrates its design for use in the production environment—right at the point of manufacture of precision parts. “This system fills the demand for high-performance gauging at the point of manufacture,” says George Schuetz, director of precision gages at Mahr. “It allows a machinist to easily set up and adapt for new workpieces, while allowing the system to act as either a long-range measuring system or as a very high-performance comparator for sub-micron applications.”
1 + 9 =
