JOFRA ASC 301 Advanced Signal Calibrator
Combines highly functional design with lab accuracy
AMETEK
Tue, 12/06/2011 - 13:09
(AMETEK: Largo, FL) -- The JOFRA ASC 301 portable process signal calibrator from AMETEK Test & Calibration Instruments provides the accuracy and functionality of a laboratory calibration instrument but is compact enough to fit into a toolbox or operate with one hand for easy field calibration.
The instrument’s robust housing makes it ideal for field service as well as workshop use, while its high-accuracy capabilities are designed to meet the demands of modern pressure sensors and temperature transmitters.
The JOFRA ASC 301 is more than a signal calibrator. Combined with a JOFRA APM external pressure module or a JOFRA dry-block calibrator, it is a multifunctional pressure and https://lh4.googleusercontent.com/qgMa1hC_CXwV1FBOYLOW-MsLU4X0sNycIWeztFVybfSpLbPH6nHmg2CGXETBgOKW9aRQp1_EWfjMKWuACen5HYidCyaGrmEC7-_oP1cAZY9NuGdu-9Ytemperature calibrator. When used with JOFRACAL calibration software, the instruments can document as well.
7 + 13 =
