Hall-Effect Rotary Position Sensors Allow Customized Configuration
A 12 million-cycle product life for industrial and transportation applications
Honeywell
Mon, 03/05/2012 - 10:47
(Honeywell: Minneapolis) -- Honeywell, a diversified developer and manufacturer of technologies, has introduced its RTY Series Hall-Effect Rotary Position Sensors that provide a cost-effective rotary position sensor solution with a variety of options (e.g., sensing range, pin-out, voltage) that allows customers to customize the sensor configuration to meet their specific application needs, especially those in harsh environments.
“Design engineers need an absolute-position sensing solution that meets their specifications without being over-engineered,” says Chris Gottlieb, senior global product marketing manager for Honeywell Sensing and Control. “The cost-effective, configurable RTY Series is an ideal solution. Design engineers will appreciate the sensor’s 12-million cycle product life and eight operating ranges, up to 360°, that often allow original equipment manufacturers the range of travel needed for the application.”
12 + 6 =
