Delta Air Lines Improves Turbine Blade Maintenance With 3-D Scanning
The MAXOS noncontact measurement system provides Delta with consistent measurements on parts with complex geometries and shiny finishes.
NVision Inc.
Wed, 05/05/2010 - 08:52
(NVision Inc.: Coppell, TX) -- Delta Air Lines uses the MAXOS noncontact measurement system from NVision in its contract maintenance operations to achieve the highest possible accuracy in overhauling turbine blades and vanes. The traditional method of measuring blades and vanes to determine the level of repair required and to inspect subsequent repairs involves a series of manual measurements.
“We have substantially improved on the traditional approach by using the MAXOS to provide consistent and repeatable measurements on parts with complex geometries and shiny finishes,” says Cameron Leonard, special projects coordinator for Delta Air Lines.
6 + 2 =
