Black Pearl High-Performance Rotational Viscometer
Offers shear- and yield-stress testing in a rugged, compact size
ATS RheoSystems
Mon, 08/22/2011 - 13:26
(ATS RheoSystems: Bordentown, NJ) -- Designed for performing both routine rheological tests such as single-point viscosity checks for quality control, to complex rheological evaluation for research and development, the Black Pearl viscometer is ideal for investigating the mixing, stirring, and process flow characteristics of fluid systems.
The unit comes standard with built-in Peltier temperature control for all measuring systems. Cone and plate, parallel plate, and concentric cylinder measuring systems are included. The measuring systems employ novel Quick Capture mounting technology. The gapping mechanism is highly accurate and user-adjustable.
The Black Pearl has an angular velocity range from 0.01 to 200 rad/s, a torque range from 0.005 to 20 mNm, and a temperature range from –10°C to 120°C.
For complete information and technical specifications, call ATS RheoSystems at (609) 298–2522, e-mail to info@atsrheosystems.com, or visit the ATS RheoSystems website.
11 + 5 =
