NIST Laser Comb System Remotely Maps 3D Surfaces
Applications for manufacturing and forensics
NIST
Thu, 10/16/2014 - 15:27
Researchers at the National Institute of Standards and Technology (NIST) have demonstrated a laser-based imaging system that creates high-definition 3D maps of surfaces from as far away as 10.5 meters. The method may be useful in diverse fields, including precision machining and assembly, as well as in forensics.
NIST's 3D mapping system combines a form of laser detection and ranging (LADAR), which is sensitive enough to detect weak reflected light, with the ranging accuracy made possible by frequency combs. The frequency comb, a tool for precisely measuring different frequencies of light, is used to continuously calibrate the laser in the imaging system.
2 + 1 =
