Italian Integrator Sees the Way to Machine Vision Success
A case study
Philip Colet
Mon, 03/23/2009 - 10:41
P
roduct information and label code verification are important parts of the packaging and quality control process for manufacturers and consumers in the food and beverage industry. Machine vision is increasingly being used to help improve the accuracy of the inspection process in these industries, saving labor, time, and money.
One specialist in this area is EyePro System, located in northern Italy. Established in 1999, EyePro System is a spin-off of ITC-irst, an Italian research center working in the field of image processing, speech recognition, and microelectronics. The company combines the diverse talents and experience of its founders in a range of activities, from performing research in computer science, statistical data analysis, pattern recognition, and image processing to engineering automated systems for industrial inspection, control, and measurement applications.
2 + 18 =
