High-Quality White Light from Four-Color Laser Source
Diode lasers could eventually challenge LEDs for home and industrial lighting
Sandia National Laboratories
Fri, 11/18/2011 - 10:18
The human eye is as comfortable with white light generated by diode lasers as with that produced by increasingly popular light-emitting diodes (LEDs), according to tests conceived at Sandia National Laboratories.
Both technologies pass electrical current through material to generate light, but the simpler LED emits lights only through spontaneous emission. Diode lasers bounce light back and forth internally before releasing it.
The finding is important because LEDs—widely accepted as more efficient and hardier replacements for century-old tungsten incandescent bulb technology—lose efficiency at electrical currents above 0.5 amps. However, the efficiency of a sister technology, the diode laser, improves at higher currents, providing even more light than LEDs at higher amperages.
“What we showed is that diode lasers are a worthy path to pursue for lighting,” says Sandia researcher Jeff Tsao, who proposed the comparative experiment. “Before these tests, our research in this direction was stopped before it could get started. The typical response was, ‘Are you kidding? The color rendering quality of white light produced by diode lasers would be terrible.’ So finally it seemed like, in order to go further, one really had to answer this very basic question first.”
9 + 9 =
