Color Measurement for Metal Packaging Manufacturers
Visual evaluation isn’t enough
Tim Mouw
Mon, 11/28/2022 - 12:02
Metallized substrates such as two-piece metal packaging are expensive to produce, and they make print color-control challenging. Although many in the metal decorating sector are hesitant to embrace color measurement, it’s the fastest, most accurate, and cost-effective way to produce consistent color across processing plants to achieve sustainability initiatives.
In this article, we’ll discuss the shortcomings of visual evaluation in a color control program, the components of a digital color solution for metal packaging, and how to determine which color measurement device is best for measuring color on metallic substrates.
1 + 1 =
