Don’t Just Set Smart Goals; Set the Right Goals
When you’re clear about where you’re going, goals become the means to get there
Jesse Lyn Stoner
Tue, 01/31/2017 - 12:02
Goal setting is powerful. No doubt about it. Research shows you are likely to perform at a higher level if you set smart goals. But how do you know what are the right goals to set?
Goals are milestones that mark the way on your journey. If you set the wrong goals, you will get sidetracked. Too often, after working hard to achieve a goal, people discover they have been chasing the wrong goals.
The right goals line up with where you want to go
When your goals are connected to a larger purpose, you see why they are important, and it helps answer the question, “What’s next?” once they are achieved. When you see a clear line of sight between your goals and your personal vision, it’s easier to stay motivated. If you choose a goal because you think it’s something you should do, it will be difficult to stay committed. This is why so many diets fail. It is easier to stay committed to a diet if you see exactly how it will help you live the life you really want.
9 + 8 =
