Prioritize a QMS Process Automation or Risk Failure
Set small, achievable milestones and allocate reasonable time for analysis
Logically, if a process is ineffective, manual, or redundant, automate it.
AssurX
Tue, 05/23/2017 - 12:01
A common pitfall in quality management system (QMS) process automation occurs with a poorly planned process automation strategy. Too often, the temptation is to automate all quality processes at once and streamline the entire eQMS process in one giant undertaking. However, real-world experience has proven that this approach is just not feasible for long-term quality management success.
What to consider
When prioritizing your quality and compliance processes, weigh the importance and interconnections each will have. The genesis of a leading-edge quality management and compliance ecosystem should start with one process determined by a key driving factor. Consider the following types of drivers when organizing your QMS:
2 + 0 =
