Optimize Supply Chain Management With Onboard Truck Scales
Weigh the advantages for yourself
Thu, 09/29/2016 - 15:03
Numerous industries need to measure the weight of goods at different stages of production and distribution. Accuracy, speed, and throughput rank high on their list. If you use outdated weighing systems, a number of challenges crop up that threaten safety, performance, and compliance with local regulations. This can be addressed by using onboard truck scales that can measure a vehicle’s gross weight or its payload weight.
Importance of onboard truck scales
Scales are installed on lift trucks or forklifts that transfer goods within a warehouse or from a warehouse to a loading dock. These scales are an excellent resource for supply chain management because they enable seamless communication between the lift truck scales and the office where the weights and logistics can be documented. The inventory of freight volume being shipped and that remain in stock can also be determined.
9 + 7 =
