When Your Lean Supply Chains Feel Out of Control, Focus on What You Can Control
Lean supply is not just about the size of inventory
Gene Kaschak
Mon, 09/19/2022 - 12:03
Many manufacturers that adopted lean principles by applying a “just-in-time” (JIT) mindset to inventory of materials and parts have been burned, sometimes badly, by cascading supply chain disruptions. Broken links in the supply chain have created havoc, especially for smaller manufacturers.
Some have scrambled to build “safety stock” of hard-to-find supplies. Others have sought out redundant sourcing. The reality is that everything is connected in your supply chain, and those connections can be fragile when they are’nt well supported.
No, lean supply chains aren’t dead. It’s quite the opposite. When your supply chain breaks down, lean systems for the rest of your value stream system will help you deal with the issue. Solutions revolve around agility and controls, not masking inefficiencies.
2 + 6 =
