EMUGE TIN Coated Thread Gages Ensure Wear Resistance and Precise Measurement
Ideal for safety-critical aerospace and medical applications
Tue, 11/26/2024 - 12:00
(EMUGE-FRANKEN USA: West Boylston, MA) -- EMUGE-FRANKEN USA, a leading manufacturer of high-performance taps, thread mills, end mills, drills, gauges, and other rotary tools, has expanded its precision thread gauges line with tin-coated gauges featuring 3B class-of-fit, ensuring that critical tolerance is met. The tin coating also ensures extreme wear resistance for safety-critical aerospace and medical applications as well as other demanding environments.
EMUGE tin-coated thread gauges have high dimensionally stable HSS construction with tin coating that increases hardness and wear resistance. This extends gauges’ lifespan and reduces the frequency of calibrations and replacements, saving time and cost. By minimizing friction, EMUGE tin-coated gauges offer consistent measurements and precision thread sizing. The tin coating also provides a protective barrier against abrasion and corrosion, even with hard or abrasive materials and harsh environments. EMUGE tin-coated gauges are available with a 3B class-of-fit in sizes No. 4 through 1 in. UNC/UNF as well as metric sizes.
5 + 9 =
