AW-Lake Introduces Cost-Effective Turbine Flow Meter
For measuring light viscosity fluids
Wed, 12/18/2024 - 12:00
(AW-Lake: Oak Creek, WI) -- AW-Lake, flow instrumentation manufacturer, has launched the TN Turbine flow meter. This meter offers a cost-effective solution for measuring light viscosity fluids, including glycol, water, and solvents. It can be used for liquid flow measurement both on or off the oilfield. Additionally, the TN Turbine flow meter serves as an easy drop-in replacement for other brands of flow meters.
With flow ranges from as low as 0.3 gallons per minute (GPM) to as high as 5,500 GPM, the TN Turbine flow meter is accurate to within ±1% of reading and offers repeatability of ±0.1% across the full range. Available in a wide range of sizes, the turbine flow meter provides multiple process connections and can work with various existing electronics. Its all-stainless-steel construction and precise machining tolerances ensure excellent durability and long life, making it suitable for even the most demanding flow measurement applications.
10 + 5 =
