Surprise! Weaker Bonds Can Make Polymers Stronger
New approach doesn’t alter other physical properties of the polymers
Anne Trafton
Tue, 07/18/2023 - 12:02
A team of chemists from MIT and Duke University has discovered a counterintuitive way to make polymers stronger: Introduce a few weaker bonds into the material.
Working with a type of polymer known as polyacrylate elastomers, the researchers found that they could increase the materials’ resistance to tearing up to tenfold, simply by using a weaker type of cross-linker to join some of the polymer building blocks.
These rubber-like polymers are commonly used in car parts, and they are also often used as the “ink” for 3D-printed objects. The researchers are now exploring the possible expansion of this approach to other types of materials, such as rubber tires.
“If you could make a rubber tire 10 times more resistant to tearing, that could have a dramatic impact on the lifetime of the tire and on the amount of microplastic waste that breaks off,” says Jeremiah Johnson, a professor of chemistry at MIT and one of the senior authors of the study, which was recently published in Science.
15 + 3 =
