Up to 20 IDS Cameras Support Nuclear Fusion Research
Laser-based approach to fusion for CO2-free, clean, safe electricity
Credit: Marvel Fusion GmbH
IDS Imaging Development Systems
Wed, 10/09/2024 - 12:03
Nuclear fusion is seen as a possible visionary solution to the energy problems of the future—clean and comparatively low-risk. Small atomic nuclei are fused at extreme temperatures and pressures instead of being split as in the reactors of conventional nuclear power plants. A similar process takes place in stars and therefore also in the sun. This generates an enormous amount of energy—without releasing CO2.
The idea of using nuclear fusion to generate large amounts of energy in a climate-neutral way is considered a dream of mankind. However, nuclear fusion is technically extremely demanding, and its realization requires not only immense investment but also ambitious research and development.
16 + 1 =
