Fine-Tuning Remote Audits During Covid-19
How an audit is conducted has changed significantly. Why audits are conducted is exactly the same.
Natalie Weber
Wed, 12/09/2020 - 12:01
Unlike Covid-19, remote audits aren’t unprecedented. Remote audits didn’t start with the pandemic, although it has forced more companies to use them than previously. At MasterControl, we’ve been doing remote audits for years for our international customers. It saves time and expense, and it’s every bit as effective as an in-person audit.
However, this is only true because we operate in a digital environment. Using a paper system would significantly hinder remote audits.
This is largely still the case. The difference between pre-pandemic remote audits and those of the “new normal” is the sheer number that are being done, in many cases by those who have never done them before. Doing a remote audit is difficult to wrap your head around if your audit usually requires scouring binders for paperwork and completing a site walk. Mastering remote audits now will be worth it even after the pandemic is over.
5 + 9 =
