Using Measurement and Software to Optimize Part Setup for Machining
Philip Hewitt
Fri, 02/17/2012 - 16:38
Aircraft manufacturing is international, with a complex supply chain dividing work among numerous companies around the world. Globalized manufacturing and outsourcing brings challenges and opportunities for suppliers.
Technical challenges include improving the quality of complex components with multistage manufacturing operations. Components must be highly accurate due to considerations of weight and assembly efficiency.
Competitive pressures require companies to be flexible with a fast response to customer needs, which often means increasing production but at reduced costs. Costs of material and machining—and the time required to remove excess material—are powerful incentives to minimize stock allowances for machining. Lead times are an important consideration in the overall costs.
This combination of challenges presents lucrative opportunities for suppliers that can meet the conflicting stringent requirements quickly and consistently.
17 + 3 =
